I have searched on this topic and believe that my drains may be clogged or disconnected; however, I have not found a good description of the location and how to either clean or verify it is properly connected. Please help with a good description (pictures would be great) of the front passenger drains and how you get to them to clean or check for proper connections. Thanks I would like to rule out these drains before I call the windshield guys.
The drain is located under the dash on the passenger's side near the top edge of the carpet. You need to pull the carpet down to access it, it is a rubber plug with a hose and feeds through the firewall at the location.
Dave
Thanks I believe that was my problem. That is the sunroof drain and it apparently was not seated good enough in the hole. I tested by pouring a little water into the sunroof front passenger side drain and nothing came out under the car (leaked inside). I pushed the hose fitting firmly into the hole and tested again successfully with water draining outside behind wheel well. Thanks again for your prompt response.
