When bleeding brakes, each half of the caliper has a bleed screw. I know the sequence in which you bleed the calipers, farthest to closest to the master cylinder, but which caliper top do you bleed first on each wheel - outer or inner?
Start with the inner bleeder, always gives a good result if done properly.
