I want to replace the OE fluid with Motul RBF600. I use a motive pressure bleeder if it makes any difference.
I have a couple of questions regarding the procedure:
1. How do you flush the the clutch slave cylinder? I had a 996 before and there was a bleed nipple on the transmission housing neer the clutch. Looks like that is gone on the 997.2 and there is a return line attached where the bleeder used to be (looking at PET)... (should be in doc od 47085500)
2. I read somewhere that you do not need to actuate the ABS pump on the 997.2 to flush the brake fluid like we used to before, is that true? I have a durametric but, if it is not needed due to a new design, it just makes things easier... (should be in doc id 300107)
I was trying to get the docs from PIWIS-TIS but they do not want my money at the moment - I get a "the payment provider is down" message.
Any help is appreciated,
T.
Edited by tcouture
1. Follow the procedure in the DIY Tutorial section here.
The bleeder is still mounted up high on the transmission as I recall. The bleeder valve is the top fitting.
2. You will need to completely flush the whole system since you are going from conventional brake fluid to a synthetic brake fluid. The two are not miscible so a complete flush is in order (including the ABS/PSM).
Thanks Loren. This is a good one...
As you indicated, I am making this more complicated because I need to flush all the brake fluid to replace it with a different type - I really need to take all of it out...
I am looking at PET 997-2 illustration 301-05 from which I believe you got your diagram, and it looks like pos #1, the "clutch operating cylinder" can also be referenced in illustration 702-08 as pos #22 (see attached).
This is where it gets a little bit more complicated... On that page, you will clearly see that there is a return line (pos #23) connecting to the top position, after the bleeder valve. I probably also need to flush that return line.
Looking at WM 300107 "Bleeding the clutch system - as of model year 2009" they seem to be using a special tool (#9781) that couples to the return line - essentially adding a bleeder to the line so it can be bled before reattaching it to the clutch slave cylinder.
Because I do not have the tool, I will try to track it down but since this is a one time thing, I am wondering how I could accomplish this without it... Since the slave cylinder is below the fluid reservoir, I can probably just fill it up and let gravity flush the line for me - but a cleaner solution would probaby be better :)
Any toughts are welcome.
T.
P.S: Also note that there is no reference to the ABS system in the 997-2 document WM 470855 "Replacing brake fluid" while it is there in the 997 section in WM 470107 "Bleeding the brake system"... 470107 is not listed when I do a search based on 997-2 vehicle type. Would that mean that the procedure changed and that ABS flushing is not required anymore? I am new to the Porsche WM and it is all a little cryptic.
post-21349-0-70929200-1301414720_thumb.j
Edited by tcouture
Thanks Loren.
Going under is my next move but won't be able to get to it before the weekend. I is still below freezing up here so jacking up the car outside is not something I am looking forward to at this juncture, hopefully it will warm up. I will report back with the results.
Also, it looks like I was editing my post while you answered, did you see the ABS bleeding comment regarding the changes in the WM? weird.
Regards,
T.
Edited by tcouture
Are you looking at the 997-1 manual?
I think the best thing to do would be to turn on the PIWIS on 997-2 and see if the ABS bleed option comes up. I think it likely will as repairs to the ABS/PSM systems or any line replacements would require a complete flush.
If I turn on my PIWIS in demo mode it does show the option - but sometimes you have to be connected to a real car to see what options are available for "that car".
I'm with you on that one... I think it is just an oversight in the manual since the 997/987 manual do have this section about bleeding, just not the 997.2. BTW, the option to actuate the pumps is there for the Durametric tool for a 997-2 with SW 6 Beta.
I am starting to think that this will make for an interesting DYI document once I have all the nooks and crannies figured out... The good news is that the dealer is 1/2 mile away if I completely mess it up :).
Cheers,
T.
Edited by tcouture
