Hello,
I have a 2006 Carrera S with the Bose system. Is the TSB available online to complete the navigation retrofit? For those who have completed the retrofit, is it worth the expense?
Thanks in advance!
I retrofitted it to a 987S (both the PCM and the navigation unit to a Bose equipped car), the procedure is almost identical. I like the factory nav, and I think it was worthwhile - but I think I'm in the minority ;)
Edited by Skidd
i have the same car as you, 06 with Bose. I had it installed at my dealer. Earlier this year i had the new 2010 disk update added. It's nice to have in the car when you need it. Maps are good. it's not touch screen nor is it as good as some of the aftermarket units. is it worth the cost? probably not, but it's OEM and i like it anyway.
bob
