Push the rocker switch, the clam shell opens, side flaps go down with a slight "grind noise" on the passenger side one, and the roof doesn't do a thing. I can reverse the process with the rocker switch so the clam shell goes back into original position and side flaps go back to horizontal (same grind noise) but thats it. No roof movement at all. I checked the E3 fuse and its not the problem. Anybody want to help me with this??? Thanks, Bob
I had some issues with my top a while back with leaking cylinders which eventually produced symptoms as you describe. The "grinding" noise in the back is likely the hydraulic pump motor, and you very possibly have lost enough hydraulic fluid that the top is no longer functioning. Had it been giving you any trouble prior to this? Do you have any telltale signs of hydraulic fluid leaking out of the front side of rear wheel arches on either passenger or Driver's side?
Hey, thanks for getting back. This is the first time I've had a problem. A forum member at 6speedonline suggested greasing the roof pump motor spindle on each side so the microprocessor could make necessary contact contact once the shell opens. Another member sent photos of a "reset button" inside the guts of the roof mechanism. I'll try both and see what happens. At least I was able to finally close the roof manually using the allen wrench and key method outlined in the owners manual. If this doesn't work I'll' try the DIY hydraulic fluid refill procedure and if that doesn't help it's off to the Porsche service department.
Thanks, Bob
  • 2 years later...
hi could someone please send me the picture how to reset and refill as my roof some funny noise and wont work now,ive used the allen keys to put the roof shut,but the locking hocks arent locked on the clam shell.
regards
john
