I want to track the car. As a result, a looooooong list of goodies is accumulating.
So, the 1999 flat 6 has a oiling issue with R-compound slicks. Where can I find a dry sump kit for the car? Is there an aftermarket one?
I want to run FAST on the track. However, in order to do that, you have to do it correctly. Fill me in. Thanks!
Chad
EDIT: the car is a 1999 996 coupe (11/98 build date)
Edited by Chads996
i believe that Brey-Krauss and Carnewal all have oil upgrade kits that solve the problem... brey krauss' isn't that expensive either.
you can check their site.
Are you going to trailer your car? If not then you wont be using slicks but DOT-R tires. Lots of people track their cars on this type of tire and as far as I know no one has had a problem.
If you want to do the conversion look at accusump. www.accusump.com.
I will be trailering my tires. I am currently developing a custom bolt on hitch that will be removable at the track. Most of the tracks are failry local. The most is 7 hours.
Thanks for the info.
Chad
