Hi Guys,
I am a little stumped right now, searched around and haven't seen another car with this combination of error codes.
Car Info:
My car is a 2002 911 Carrera 2 w/ 60k miles
I just replaced the Maf with a brand new unit from Suncoast.
P1109 - Input variables, charge measurement
Above limit
P0430 - Factory Fault Code 45 - TWC conversion, Bank 2
Above limit
Any ideas as to what I should be checking? O2 sensor? which one? Catalytic? Thanks in advance
post-37491-0-42599100-1300724954_thumb.j
P1109 Input variables, charge measurement - above limit
Possible fault cause
- Heavily soiled throttle
- Throttle adjusting unit faulty
- Mass air flow sensor faulty
P0430 TWC Conversion, Bank 2 - Above Limit
- Oxygen sensor ahead of and after TWC exchanged
- Valve lift fault
- Aged oxygen sensor after TWC
- TWC faulty
I would start with a good cleaning of the throttle body and MAF (using the proper cleaners) - clear the codes and test again.
Shoot, forgot to mention that I did clean the throttle body yesterday. MAF is a brand new Bosch unit from Suncoast.
Code came back exactly the same after the cleaning.
