Hi
May be somebody tried this:
Is it possible to install CDR30 in boxster 2001y instead of CDR 220 + cup holders?
Will be there any problems with connectors?
Not really - the MOST system is a fiber optic network and you would need to add all of the components including the gateway.
It is not terribly hard to go MOST -> older wired systems but it is nearly impossible to go older wired systems -> MOST.
Thank you!
I decided to stay with CDR 220 and use AUX in cable
