I just had a new PCM2 unit installed in my 2004 996 and I have 2 questions. Is the only way to turn on navigation without the radio playing by selecting 'mute' in the audio section? (In other words, can I get in the car, turn and turn on navigation without turning on the radio?) Also, I noticed that from 12:00PM - 12:59PM, the display shows "am" and then changes to "pm" at 1:00PM. Is this a bug? Is there a fix?
Edited by Loren
Look at the 996 TSBs. There is one for the wrong time displayed. August 14th.
With a retrofit PCM2 the unit may not be coded properly.
I did see that TSB. The PCM2 unit keeps the correct time (hh:mm), but just during the 12:00 noon hour, it displays "am" instead of "pm". I didn't see a TSB on that particular issue, but I'll be going back to the dealer to see if thay have a solution.
Thanks.
