Does anyone know how to turn off the fasten seatbelt sound? (Don't worry, I always use my seatbelts, but I just get annoyed by the sound going off after just tapping the gas pedal.) I have the latest Durametric software and cable. I'm having some issues with the rear Park Assistant not working properly. How do I use the Durametric to troubleshoot this? I have a 2005 model.
:help:
I am not aware of the option to turn off the chime.
That's what I thought. Thank you for your input! Do you have any thoughts about troubleshooting the rear Park Assistant?
SorryI won't be much help with the PDC as the only problems I have seen were due to the sensors being dirty. A quick clean and they were good again. RFM has much much more experience with the Cayenne then myself so maybe drop him a note.
What about turning off the automatic locking of the doors upon vehicle movement? An easy computer code change in my Audi's, hoping Porsche has something similar to program it out.
You can take care of this on your own via your vehicle's built-in Multi-Purpose Display -- see your owner's manual.
For the 2004 Cayenne S and Turbo it's on page 108 & 109. Turn off or on the auto lock feature. "If the AUTO LOCK function is active, the doors lock automatically when the vehicle exceeds 4mph (6km/h)."
post-41432-0-89005000-1300763640_thumb.p
post-41432-0-49534100-1300763649_thumb.p
Edited by odix
Thanks Odix, I'll check my manual tomorrow. I've only had the Cayenne two weeks but drove it 2950 miles in the first 3 days so I thought I was real familiar with all of the setting but I'll check the manual and look again. Mark
And be sure to keep in mind some of the Multi-Purpose Display functions are only available when the vehicle is stopped. If the vehicle is in motion the amount of options, for safety's sake, is truncated. After I bought my Cayenne S, an '04, I bought a CTEK 3300, plugged it in and sat in my vehicle, ignition on but engine off and spent hours studying the Multi-Purpose Display and PCM functions.
