Guys,
'98 Boxster 5 Speed, 82,000 miles
Among other things, at 41,000 miles (2 1/2 years ago) the car received new fuel filter and new Bosch Platinum 4 plugs in the correct heat range. 41,000 later this is the first issue of this type.
Two weeks ago i overfilled the fuel tank and got an evap cannister CEL and cleared it.
Today the CEL came on so I headed for home to check with Durametric. Just as I pulled onto my street the CEL started to flash and there was hesitation at around 3000 rpm's so I coasted in.
Durametric shows P0300, P0305. P1317, P1319 all misfires (Cylinder #5??).
I searched this site and saw several examples of similar issues. "A leak in the air intake, Connection to the plugs were not plug-in correctly, Need new fuel filter, The platinum plus 4 are not good for the boxster, Coli packs need replacement, Vario-Cam sensors" to name a few.
Any suggestions of where to start as a process of elimination?
Any help greatly appreciated!
Regards,
Clearly the problem is on cylinder 5.
I suggest you inspect the electrical connector, coil and remove and inspect the spark plug on cylinder 5.
Thanks Loren,
Will do and I will also report back as to what I find.
Regards,
Loren
Turned out to be coil pack on #5, I am back on the road and car now runs great. I have 5 more coil packs ordered along with 6 new plugs as it has been 40k since last changed.
