Is it possible to put a Turbo Tiptronic transmission (model A9650) into a C4S (which normally has model A9635)? These are both Mercedes Benz 722.6 transmissions.
Given the number of views without replies, I figure I should add a little detail to my original post.
Basically, I have a 2003 Carrera 4S that has a Tiptronic transmission. As a result of a small leak coming out of a set of seals (that I and my mechanic are carefully monitoring), the spectre has been raised that I may need to replace my transmission at some point in the future.
I currently have an A96/35 Tiptronic S transmission (manufactured by Mercedes for Porsche), which was in the 2002 to 2005 Carrera 4 and 4S models. The 2000 to 2005 Turbo Tiptronic models had the A96/50 transmission, which is the same on paper (as far as I can see in Adrian Streather's book), except the final drive ratio is 2.89:1. Of course, these are both AWD models.
Further to the above, I have started hunting around for another transmission, and at an early stage I have noticed that there seem to be a lot more Tiptronics from Turbos (the A96/50) that are available on the market.
Thus, my question is if anyone knows if my 2003 Carrera 4S, which originally carried an A96/35, would be compatible with an A96/50, designed for the Turbos.
Loren or anyone, please enlighten me. Thanks!
It will not work. The flex plate for the turbo is 9 bolt and yours is 8 bolt. The bell housing bolt pattern is different on the transmission housing. etc. etc.
