Rear speakers in the panel under the rear window?
If so, then carefully remove the trim piece with a door panel tool (plastic spatula) and then remove the screws underneath.
I think you pop out the rear side panel speakers by using a credit card around the edge of the cover, and then use a torx to unscrew the speaker mounting from the cutout. Someone may know differently, but I think that is all that is required to get to the
speakers.
Good luck.
DC
