think the title says it all. Im going to have to add an aftermarket amp and was wondering if I can tap off of the wire that charges the aux battery... or do i have to run a wire from the battery under the seat?
You should be fine to run off of the second battery. No issues that I can think of.
Good luck.
DC
I read something today about the wiring orientation of that battery. It was somewhere in this Cayenne forum in a thread about constant dead batteries. It said something along the lines of that battery is only used for starting an engages at the command of the ECM.
Your idea sounds ok to me but I wanted to throw this out there.
