I am new here and couldn't find anything on my specific problem yet - i don't want to litter up the forum so in case someone knows about an existing discussion please advice and will
add to the existing thread. thanks.
So here a short description of the issue:
I moved from the US back to germany 2 month go and shipped my car (2008 997.1 4S Coupe) over as well, upon arrival i took it for a ride and noticed that the a/c controls and seat heaters were not working (no feedback led's and no function). I checked the fuses and the 25A fuse for the climate control unit was blown. i replaced the fuse and all was fine until i took it out again last weekend... when shortly after starting it up (outside temperature 25F) i turned on both seat heaters and hit the button for the windshield defrost. It went dead again and guess what - yes the fuse was blown again.
Before i shipped the car i had a aux in adapter added to my pcm 2.1 that lets you keep the cdc. it is hooked up to the fiber optic cable of the pcm and can be activated/deactivated with a button.
it also has a charging device built in to charges the ipod while connected. the aux in however works fine even with the fuse for A/C blown. Well, it shouldnt have any interference with the A/C in the first place since its hooked up to the PCM i think but just trying to provide any info that might be relevant. could this have anything to do with the batterie being connected/disconnected or maybe jump starting during the shipping/transport process? is there any risk of a malfunction/cable fire..? what can i do to diagnose/fix the problem?
Has anyone encountered the same/similar problems?
Other than that problem the car and all functions/features work to spec as far as i can tell.
Thanks in advance for the support!
nat
I don't have a copy of the 997 wiring but from what you are describing I would verify you do not have a shorted seat heater first. From your description it sounds like the fuse blows when you press the seat heaters. They are a resistance wire that heats when current applied, perhaps one of them shorted out. Not that uncommon.
R/Tom
I have seen a few cases where the wiring for the seats(heater,airbag,power seat motors) has become caught in the sliding mechanism.
