Vehicle is a 1997 993 C2S
Right rear and right front running lights do not work. I've reviewed the fuses listed in top of fuse box to try and find which fuse is out. All I can say is if it's there I must be blind because I can not seem to find it. I'm not talking about daytime running lights, just the ones that go on when you turn the light switch on
Also top of fusebox does not show relay for right front and right rear running lights. Is there a relay that is used for this purpose?
I have no running lights at night on 1997 C2S on right front and right rear.
I noticed this after I changed oil, but I don't know if those lights were functioning prior to oil and gearbox fluid changes. Just mention in case it may be relevant.
Thanks for any help. Posted on Rennlist yesterday and no responses.
Edited: I did find more relays and fuses in drivers side rear motor compartment but they are not the ones I'm looking for.
Ignore post problem solved.
Edited by Ron in Charleston
