Hi~
I looking for used my00 boxster s instrument cluster over 1 years cuz my LCD broken, but I cannot find out T_T
I know if different LCD shape or cable color, cannot swap,
but yesterday I found my00 boxster(non s) instrument cluster in ebay, that has same LCD shape, same cable color, same rpm redzone with my boxster s.
Ah, same manual gear box also.
Can I use it?
i think the speedo on the s goes to 175mph and the regular one goes to 150mph don't know if that makes a difference at all...
yes. my 986s speedo 175mph but, seller's 986 speedo 150mph.
I dont care the number scale if it work zero to max. cuz I can swap speedo number panel.
but... I wonder it will work hmmm.
Is there anybody tried this, before?
HI i did do this on my car, worked without problems, only your milage meter is a little off..
Thx sliderr for reply. I'll try swap my instrument cluster^^
Make sure you don't lose the connector from your hazard lights when you decide to disconnect it all, make sure you put something on it so i wont disappear behind the dash :)
thx sliderr. I'll check it up ^0^
I need to wait about 15 days, cuz oversea delivery from usa ebay.
