Start at the beginning: Fuel delivery (pumps)? Spark? If neither of them, check crankshaft sensor, connectors, wiring's and fuses. If all goes well you will still have a diagnostic tool for further investigation.
It could be an immobilizer fault. Lock the drivers door with the key, unlock using the key fob and then see if it starts. If the scan tool will not communicate with any module then check all fuses using a test light.
