My 99 Tiptronics makes a banging noise when it shifts, this happens when i accelerate the car from first to second gear, if i drive it slowly its fine, when happened i was thinking its the antifreeze bottle that is moving around in the trunk, Does transmission have a mount? or what should i check. Thanks in advance.
If the front mount has never been changed in your 99 Boxster, that's probably the best place to start. How many miles does it have? There is a DIY in the 986 DIY Tutorial Section that might be worth a look. It is not difficult.
Keep us posted!
Edited by kbrandsma
Keep us posted!
Thank You for the reply, It has 72K, and i'm sure it was not changed, Just orderd the front mount and i should have it tomorrow.
