I'm in the market for some speed bleeders - so I can bleed the brakes on my '02 C2 by myself without the need for a helper.
Any recommendations or should I stick with the helper?
thanks,
kristap
You can also use speed bleeders. These replace the normal bleed screws with one way ball valves. You loosen one then as you pump the brake pedal fluid comes out but air will not come back in when you release the pedal. You keep topping off the reservoir as you bleed each caliper. They are $7 each and you need 8 of them.
www.speedbleeder.com
