hello all
i hope you can help me. my car 996tt 02 is flashed + exhaust by sportec.ch. I have installed IPD plenum with BT 75 mm and the car give psm / abs default P0103 code 115 (maf) and p1109 code 594+5525error data. I changed a new maf, but that is the same problem. I turn back to original installation and all ok
you have ideas
thank you very much
alain
Welcome here, Alain!
When you say "turn back to original", I guess you mean back to the Sportec setup, but without the IPD plenum, right? BTW, do you have the Sportec Stage 1 upgrade?
I'm sorry I can't help (just have no clue), but I wouldn't do any 'external' mods to an already chipped engine. Having a patchwork of optimizations probably doesn't help on the long term.
Anyway, I hope someone here will be able to help you!
P0103 Mass Air Flow Sensor - Above Limit
Possible fault cause
- Intake air system on pressure side (between turbocharger and engine) leaks
- Short circuit to B+
- Mass air flow sensor faulty
- Throttle jacking unit faulty
P0115 Engine temperature - signal implausible
- Thermostat (permanently open)
- Open coolant shutoff valve (only Tiptronic vehicles)
- Wiring
- Temperature sensor faulty
- DME control module faulty
P1109 Input Variables, charge measurement - above limit
- Heavily soiled throttle
- Throttle adjusting unit faulty
thank you all for your help, my car was in fact the stage 1 and works great
Does the car refuses the plenum or BT?
the manufacturer about an adaptation period of 5 to 55 miles, I have driven for 100km without matches
Should the ECU reflash?
Good evening thank you
