Hi, I have a problem with my cayenne turbo, fans don't work until coolant reaches almost 210 degrees, they work until temp goes back a little then stop working again. But temp wont go back to normal
I've read in a boxter forum that this is a low fan speed problem that is caused by a ballast resistor that goes bad. I wonder if the same problem happens with the cayenne
Thanks for your help
Edited by pabloaviles24
Hi all, i'm new in the forum.
I have the same problem, when idling temp is normal but as soon as i hit the gas temp climbs to 3/4 of dial, fans don't work until temp reaches 3/4.
Please let me know how to fix it.
