part # & price for throttle body
  • 3 years later...
Loren,
UBD II code is 1502, probably the Throttle valve or body. The porsche specialist here said this code means replacing this part. Is this true?
On our advise he was cleaning it first well, but still same code after doing the whole starting/ resetting procedure.
Do u think it is this throttle body and can i order this for this price here?
hope to hear,
Harry
986 605 115 01 Throttle Body $332.85 (retail as of Dec 2004)
Loren,
hope to hear,
Harry
P1502 Throttle Jacking Unit, Spring Test – Above Limit
It says: Replace throttle part.
Perform adaptation.
1. Switch on the ignition.
2. Wait one minute. Do not press the accelerator.
3. Switch off the ignition for at least 10 seconds.
4. Read out the fault memory.
thanks a lot Loren,
I will change the trottle body, unforgenatly quite expensive here, 800 euros, but if then the problem is over.
Will let u know
Boris
Loren,
hope to hear,
Harry
Perform adaptation.
