you'll recall the engine would not rev over 4K and I was getting the P1579 code. I got in the garage this weekend and removed the tranny and here is what I discovered. The head on one of the small bolts that holds the friction surface to the flywheel had broke off. The bolt was then bouncing around inside the bellhousing and bent one of the shutter wheel teeth. That is the tooth that was hitting the CPS.:
You can see some scaring on the flywheel where the bolt was hitting the bolt holes. It sucks to have to do this all over again, but Aasco has been very easy to work with has a new unit on the way. If something happens 1 out of 100,000 times, gotta figure it'll happen to me! Don't come near me during a thunderstorm!
Byron:
Excellent work finding the cause, even if it was a PITA.
You might want to reconsider the lightweight flywheel option.
FWIW, at Sebring two weekends ago, one of the cars campaigned by a racing group from New York broke a crankshaft on a 996 engine that was running a lightweight flywheel.
Charles Navarro of LN Engineering, as well as others, have long cautioned against the use of lightweight flywheel unless the engine is disassembled and the crankshaft and flywheel are balanced as one unit.
Regards, Maurice.
Byron:
Regards, Maurice.
+1...........
  • 6 years later...
