I just got done installing a window regulator on the paadenger side of my 03 C4S. Everything went perfect except for when i went to start the car he airbag light came on. I discinnected the battery before i started work on the door. Removed side air bag and set off to the side like normal. Never had an airbag light go off. Anything I can you?
The only other thing I would recommend is dis-connect the battery
for 5 minutes. You will need to teach the car how you drive and
reset all your radio stations. Hope this works.
Paul
Paul
Disconnecting the battery will not reset the airbag light.
The Durametric unit will reset this light. I know because I disconnected, removed, and then reinstalled my driver's side door air bag to repair the door mechanism and the light came on as you described. The Durametric easily cleared the code.
