could anyone help me sync these error codes with further repair instructions:
________________________________
Porsche Stability Management - PSM
Current Fault Codes
4444:
Steering-angle sensor not initialized
___________________________________
Airbag - POSIP
Current Fault Codes
8023:
Driver's head airbag short circuit to ground
8009:
Driver's belt tensioner above upper limit
Upper limit value exceeded
800A:
Passenger's belt tensioner above upper limit
Air Conditioning
Current Fault Codes
C203:
Fault steering wheel electronics control unit (drive)
Implausible signal
_____________________________________
i tried to initialize steering sensor with durametric, but nothing really happened.
thanks for your answers
You may want to find a Porsche shop with a PST2 or PIWIS tester.
PST2 will still work on a MY2005 car and the likelihood is better that an independent shop will have one.
Will any of the codes clear? With the car running, turn the steering wheel left and then right past 45 degrees, straighten the wheel and drive a few meters ahead in a straight line to see if that calibrates the steering angle sensor.
