2004 Cayenne S with 165,000 miles
My drivers door lock will not work with the key or the remote and I also noted that the
inside light wont come on with the drivers door. Can anyone help me with how to remove the Drivers door panel
or what I might do to repair my lock?
DB
Another Cayenne defect. I have the same issue on front and rear drivers side. I have never owned a vehicle where the locks failed! Try taking the round rubber grommet out that has a circle with a slot diagram on the outside of the cover (located on the side of the door where the latch is). Under that cover is a slot that you can put your key in and turn it to override the lock system. It should also be in the owners manual. Good luck!
Did you try the reset?
  • 5 months later...
comfort control unit or kessy control unit
Dealer or someone with PIWIS
Edited by mudman2
