Got a new thermostat from Porsche along with a water pump etc.
The thermstat (TS) was without the housing and as I have been reading I may need a special tool the remove the TS from the housing?
Can anyone verify this?
I can buy an after market one from Pelican that has the housing as a single unit for about the same price. Which I will do if I need a special tool for this simple job :rolleyes:
Yes, a special tool is need; in fact, it is so “special” that only Porsche sells it for a little over $100. But you can make one yourself in about 15 min. with some scrap tubing, a hack saw and a file………………
