hey guys I have a 02 turbo awd with leaking clutch slave.Replaced slave,hydro accumulator,and master cyl.The car was driving normally only had a leak.Replaced all parts and pedal is so stiff you barely depress pedal checked new slave found it binding inside,so reinstalled orginal slave and the pedal is still stiff.bleed system no air and used corrected fluid.I have now removed eng/gearbox removed gearbox disc is worn but not worn out.This is the first porsche I have worked on clutch (bosses car).So any ideas would help.I followed all instructions in alldata for the repairs to this point.
I assume you've run the engine to repressurize the system?
All fluid reservoirs are filled?
Have you replaced the accumulator?
Is there a difference in clutch feel with and without the engine running?
Some more information will be helpful.
from my limited knowledge, if the clutch goes back to normal feel after the engine is started, its the accumulator. which is a very commom fail item.
