Hi. I've finally rejoined the Porsche family again after a 10 year hiatus after selling my 83 SC :( . I purchased a beautiful 2003 Boxster S and I'm in the initial stages of collecting the proper tools and materials to maintain and upgrade. It appears that Durametric is the standard for code reading and programing. I use Rosstech for my Audi and it appears similar. Are there any other options other than the factory PIWIS that I should take a look at or is the Durametric the one to own?
Scott
:welcome:
Unless you have $18,000 a year to lease a Porsche PIWIS tester then Durametric is your choice.
Durametric can do most everything the average DIY'er will need.
How about the AutoEnginuity unit?
You will only be able to see engine codes with a generic code scanner - no alarm codes, no airbag codes and you won't be able to test Porsche specific hardware.
The Durametric is very comperable to Ross-Tech's vagcomm. Allows you to see and talk to every computer on the car. Unlike ross-tech they offer a home and a pro version, the home version will only let you use on three different VINs. They pop up on eBay alot used on one car.
I have a generic OBD2 reader for checking temps and such, but use the Durametric for serious stuff. I bought an older version used, can use it on multiple cars.
Pelican Parts sells them for the same price as direct. I've never used PP before but I plan on purchasing various things from them. I'd buy from a dealer instead of direct because it helps everyone out.
