Hello All
I was browsing online for brake pads and I noticed ceramic type pads that boast 80% less dust, and then the standard semi metallic. I have not inquired about whether rotors need to change, and I would not change rotors to accommodate new pads. Does anyone have experience with the ceramic type..are they compatible with steel rotors, how do they stop and wear and is there dramatically less dust?
Thx Rick
Thx to all that replied. I decided on the Hawk HPS semi-metalic and have changed both front and rear. I was able to reuse the sensors by prying them out carefully.
So far so good!
Edited by RicksCarrera
  • 4 weeks later...
I have ceramic and they are great for stopping distances, etc, but when cold and driving (normally) in the city they make squeaking noise a lot! ... you got to press really hard severall times to warm them up and then they are quite!
Just throwing my two cents in... My Brake Workshop light came on about four weeks ago, and I replaced the pads myself with the Hawk CPS pads after about a week and a half. This was the first time I had ever attempted replacing brake pads and it was WAY easier than I expected it to be (with the exception of removing that pin, I wailed on that thing forever before it finally budged).
I absolutely hated the Porsche OEM pads throwing hard to remove black dust all over my gorgeous 20's, so I went with Hawk this time. My wheels have stayed nice and clean for two weeks now and I really have no complaints at all about them. They brake just as well, I haven't noticed any increase in noise, and everything fit great.
They were a lot cheaper than the OEM ones, and doing the job myself it only cost about $25 for the sensors and $125 for the pads... much, much better than what I paid last time.
I have had good luck with the Hawk HPS in the past but lately on my cars I've been using EBC Reds & Yellows. They are cheaper and seem to be easier on the rotors and quiet. The Reds are completely no squeak and very low dust. The Yellows have an occaisonal squeak but may not be fully broken in yet and a little more dust than the Reds but less than OEM and they bite a little better than the OEM or the Reds.
