Are the clear headlights for 1999-2003 996 interchangeable with the clear headlights from the same year Boxster? Any difference? I need a clear passenger side for my 996 and I found one new and it is about $60 cheaper for the Boxster light. It looks the same but I wanted to make sure. Thanks
Yes and no.
Carrera headlights are the same 1999 to 2001 Althought the 1998 builds and early 1999 builds had orange turn markers (inside the headlight) . So the clears are all the same. until 2001. The body style changed with the mk II in 2002 - as did the headlights.
In Boxster headlights - they had the orange turn marker (inside the headlight) I believe until 2003.
Look at the pattern inside the housing. The 996 clear headlight has a diamond/grid pattern where the 986 clear headlight has a linear/fluted pattern for part number 986.631.132.14. Otherwise, they are interchangeable.
Edited by slbates
Thanks, I see the difference now, especially the pattern on the inside. I hadn't noticed that and I would have goofed and they wouldn't have matched. Thanks!
