I have a 2007 997.1 turbo with 12.000 miles. The car is warranty until September this year. Since I got the car on May 2009, I have had the same problem with my tiptronic. Sometime during shifting from the 2 to the 3th gear only, the engine rev up without engaging the 3th gear and then it finally engage hard... really hard... I don't have this kind of problem when I drove at high rpm's or on any other gear change, only during smooth driving... Anybody had tiptronic problems like these ?
The solenoid valves had been changed by Porsche already, and the problem remains the same. Can you help me? Should I ask them to replace the complete transmision under warranty?
Just for your info, Antonio, I have the 2007 turbo with 24000 miles and don't have that problem. I would pressure them to fix it.
Good Luck
