]My passenger seat has a wierd vibration when car is idling? My wife notices it at stops. Car is tuned, idleing fine, running fresh. Wondering if it is a mount on the Trans-engine or seat. When I increase idle at stop the vibration diminishes and then returns. Perhaps picky but dosent seem correct for this car.
996 TT 2001 23k miles.
Any suggestions? Thanks.[/font]
Steve:
The first logical step is to eliminate the possibility that any of the four bolts that hold the two seat rails to the frame are not loose. Those bolts have a male Torx head, but in a pinch you can use a 1/4 inch drive 10mm socket to torque them down.
Here is a photo of the each of the bolts at the rear of each seat rail:
post-6627-0-30104900-1296272288_thumb.jp
Here is a photo of the bolt at the front of the inboard seat rail:
post-6627-0-91862000-1296272266_thumb.jp
Regards, Maurice.
Edited by 1schoir
Mine shakes too - I posted a topic about this (don't recall which site / forum) but all responses said the shake is normal and that their's shook as well. I wrote it off at that point thinking I might be too critical but will be interesting to see if you find anything specific about the shaking. I can say for sure my seat bolts are tight so that's not the problem in my case. The seat back is what I see shaking - essentially back and forth from front to rear in terms of direction. Really noticeable when the seat is devoid of a passenger.
same for me, seat back is what is shaking. Bolts are tight. I thought maybe it was ruff idle or some drive train mounting point broken. I think it is just the car.
Agreed - I noticed this morning my idle was around 850 RPM's when it was shaking. Gently touched the gas to get it to 900 RPM's and the shake stopped and idle was smoother. Was thinking maybe going with a mod to see if that would correct it but not sure since I recall you had yours modded already. Haven't had a chance to look-up what the exact idle speed should be but could be this is why not everyone experiences it.
This was happening before I flashed my car. I have new plugs in car and I think it just needs to have Idle adjusted or maybe a true service. Car runs perfect to me, I have essentially done the 30k service in stages in last 1000 miles. Oil,plugs,brake bleed,diff fluid and some upgrades to hoses,dv's,computer, intake. I can live with it and actually I dont know if a 30k service for my car includes more or less than what I have done. Can you manually adjust the idle?
