Need a wiring diagram for 1992 C2 convertible top. The top is inoperable. The switch is good, fuse good, but no power to motor??? Could be a relay but not sure without diagram. Anyone???
Thanks for diagrams, Loren. Still unable to locate source of problem, do you happen to have the diagnostic procedure from the 964 manuals for the convertible top? One set of manuals I don't yet have! Thanks.
Okay, if you have any thoughts: if we jam voltage on the motors to move the top half-way it will operate in the down position but will not go up at all. We removed switch and bench tested, it's good. Leaning towards control unit.
