Relay position 8 on the DME relay panel.
Fuse is a 40A fuse on the same panel.
The DME panel is under a metal plate that you get to behind the rear seats.
WOW! loren thanks, you always answer my questions, where did you learn so much.... you should teach at Porsche.... :)
Edited by zappiros
Disabling the secondary pump relay will also disable the changeover valve operation and improper operation of the resonance valve will occur. This will greatly change for the negative the power curve of the engine. The removal or disabling of this relay will also cause a CEL
There is absolutely no reason to disable the air pump as it only operates at cold starts for a few minutes.
If, however, you do so, you will need to design an alternative method of operation of the resonance valve, or just accept the reduced performance of the engine.
Edited by 1999Porsche911
