Loren,
I just got the following in an email. When I kick on the link it doesn't take me to a forum or my private message area, even when logged in. I then went to look at my private messages and don't see anything in there beyond 1.5.11.
Is something being buggy?
rsfeller,
rrotondo has sent you this email from http://www.renntech.org/forums/index.php.
I see you no longer have this DIY on your site. I was hoping you could email me the write up or a working link. I am getting pelted with Foam and it is getting in my eyes so its a bit dangerous as well.
Folks you saw your write up said it did the trick - so it would be much appreciated
Please note that RennTech.org Forums has no control over the
contents of this message.
If you go to your My Settings and then to Notification Options. Is the checkbox for Hide my email address from other members checked?
If so, then any member can send an email (rather than a PM).
To prevent this simply uncheck that box - then they can only send you a PM on the board. (that is what I do)
Understood. Did the interface change again that it defaulted to this? I don't recall ever getting emails directly to me before...always thru the PM system.
Thanks.
