On my '00 996 C2 I have been getting repeated P1130 and P1133 codes. Also the RKAT on the same bank (2) is close -4 (just within range), while RKAT on the other bank (1) is close to 0. Already changed the MAF (tested with Durametric and voltage changes with RPM's) and searched for vacuum leaks with propane. Also, disconnecting a vacuum hose after a good hour after turning the engine off, gives a good swoosh, indicating that the system is holding the vacuum OK.
I am at a loss....
Joost
I am at a loss....
Joost
I've not used propane. I have used starting fluid.
Joost, I've attached the OBD guidance for error p1130. It outlines five potential problems to check out. (the fifth is the note at bottom regarding possible exhaust leak). Also, I can't find a 1133 error in the guide. could this be error p0133? (oxygen sensor aging)
Hope this helps. Glenn
OBE guidance for P1130 code.pdf
