Hey guys,
I am the new owner of a 08 Cayenne S and recently got the brake pad workshop message. I did the pads myself with all new sensors too. I just patched everything up and started the car up and still have the Brake Pad Workshop light on.
Do I need a scantool or something to reset the light?
Likely one or more of your sensors is not connected. If there is an "open" anywhere in the sensor loop it will turn the light on.
Check your connections and sensors to make sure none are broken.
I had this issue on my 996 over the summer. I had to add a little silicone grease to the electrical connectors to get them to finally push all the way together and shut off the light.
Bingo!
One of the sensors was not plugged in all the way.
Thanks for the help. I am glad I found this site.
