Last night I noticed that the indicated water temperature was slightly below the usual 80-85°C, about 75°C
This morning, it took 8 minutes before the temperature reached 60° and after a 20 minute ride, it wasn't still on the usual 80-85, it was somwhere around 70-75°C.
It's the first time I noticed this.
Is it dangerous ? I hope not, since it's the oil temperature that is important.
Can I go full throttle up to 6000rpm with the indicator below 80°C ?
I've got a 2002 4S.
Make sure cooland level is correct and properly bled. An air pocket can cause the gauge to read improperly. I doubt you coolant temp is as low as the gauge indicates. You may also try resetting the computer, Many times I have gotton screwy gauge readings and a simple computer reset fixes them.
This makes sense. I checked the water level and it's clearly UNDER the minimum level. I wonder how this happens, since the car has got his servicing only 5000 kms ago !?
Can I safely drive to my Porsche-dealer (25 kms) without adding water ? It seems one should fill up with water and coolant mix, but I don't have this (and all shops are closed today and tomorrow).
