I have a Boxster 2.5 1998, if I leave the car for more than 4 days the battery is flat, it has had a new battery, still doing it, some one tells me it may be the alarm as it is on the floor and damp my be causing a problem. Is this common? or does anyone have any ideas cheers all
:welcome:
Average draw is 40 to 60 ma.
Put an amp meter in series with the battery and measure the current draw (key off and removed).
Remove one fuse at a time until you find source of the drain. That will point you to the circuit with the draw.
Then report what you found here and we will help you trace it down further.
