I was just informed by a reader of my book that Project #17 is somewhat unclear with respect to the torque values used to tighten the idler pulleys. I just added this information to the corrections page on http://www.101projects.com/Boxster/corrections.htm :
Page 81, "Replacing Belt Tensioners", the torque values listed for tightening the pulleys require additional clarity. Tighten the pulleys to the following values:
Upper Pulley:
- 34 ft-lb (46 Nm) for the upper bolt if it's an M10x145 (8.8) bolt
- 48 ft-lb (65 Nm) if it's an M10x145 (10.9)
Lower Pulley:
- The lower pulley is tightened to 17 ft-lb (23 Nm) only
-Wayne
