Not certain of your specific issue, but have you looked at this:
http://www.renntech.org/forums/index.php?/tutorials/article/28-cracked-or-bleeding-climate-control/
I have performed this repair recently and found it to be both easy and low cost (~$50); furthermore, it (1) does not require any reprogramming that may be required with a new control unit, and (2) replace an old part with new part (which I prefer relative to used parts that may fail in short order).
Good luck,
-tanny02
  • 9 months later...
http://www.renntech....limate-control/
Good luck,
-tanny02
Curious, what did you search for on Ebay to find the replacement LED panel? I'm not having much luck.
Chris
