Anyone know how to modify the roof electonic controls to enable roof to be lowered or raised whilst driving at low speed (like the 996 cabrio models)?
You remove the top relay and break off or bend pin 18, which defeats the speed signal. If you want to defeat the need to pull up the brake you solder a ground wire to pin 15.
A neat thing that has just come out in Germany is SmartTop and it has good reviews on the German and UK Boxster boards. This is a modified top relay. It does the same thing as the TechArt relay and TouchTop, but it is one part. Simply exchange the oem relay with the SmartTop relay. They only have a modified relay for MY00 and newer, but say they are working on My97-99. Jeff
Pic from Jason of oem relay with ground wire.
Thanks for the info, Tool Pants (great handle!). I tried a google search on SmartTop but got nothing (apart from the usual porn, etc). do you have the web address?
Just to let you guys know I bought the relay from SmartTop & it works perfectly. Cost for the relay was €238 incl P&P, delivery was within 1 week following a money transfer order. I'm well pleased :clapping:
