Hey guys,
My car is a 2002 S and though it only has 33k miles on it I figure I'm going to change the plugs, serpentine belt and filters as I do not believe the plugs / belt have been changed yet. The car hasn't leaked any oil at all (thankfully), but I figure if I'm going after the plugs I should do the tubes / o-rings at the same time.
Is it worth changing it if they're not leaking?
Edited by tawheed
No need to change the spark plug tube o-rings on a MY2002 - you already have the newer style.
Loren, didn't the transition to non removable tubes happen in 04-05?
Edited by JFP in PA
Yes, but I was referring to the newer style o-rings that were put place in 1999.
Thanks for the information, guys. I guess I'll leave it be as so far, thankfully, so good. If something happens down the line I'll worry about dealing with it then!
My 02 S has removable Tubes and they leaked. I replaced Plugs, Tubes, and O-Rings at approx 90K miles.
I would NOT touch a thing if they don't leak. Only 33K miles? WOW!
Guess you can take a look when you remove the rear wheel and access panel.
I did my plugs, tubes and o rings this last summer on my 2000S with 90K (at the time) miles. My tubes were not leaking but I decided to be proactive and now wait for a leak. Tubes only added about $50 to the job and now (hopefully) I don't have to go back in anytime soon.
Using the 1 inch transom plug to remove the tubes was well worth it.
Yes, definitely a low mileage car, don't get much driving time up here in Canada :)
Maybe I should take a peek before ordering parts, I haven't seen any oil on the ground but I guess that doesn't mean it's not leaking.
One more question - if I do decide to do them do I need to spend $50~ on the Porsche grease or can I use just about anything to grease the o-rings?
Edited by tawheed
I DID purchase the Porsche grease and I used so little of it. I don't remember spending that much $$ though. Contact Sunset Imports at the top of this (Renntech) link. You cannot beat their prices!
