I figure it's time to flush the brake fluid in my '99 996, as I've had the car for a year and have no idea how long the fluid's been in there.
The Motive brake bleeder pump looks pretty nifty, so I'm going to invest in one of those. I guess my two questions are:
1) What's a good fluid for a daily (spirited) driver and occasional autocross car? (hope to take the car to a PCA track day or two this year, also)
2) How much fluid do I need for a total flush?
thanks!
Dave
Edited by DaveFL76
Thanks, yeah I found that DIY already. Awesome writeup; actually that's what gave me the confidence to want to do it myself.
I'm a bit hesitant to go to the dealer and get fluid that's probably 2x the price of something comparable that I can get online or at my local parts store. I was hoping folks could chime in with some fluid recommendations...
EDIT... just looked up ATE mentioned in the instructions... didn't realize it was a brand name. Now it all makes sense!
Edited by DaveFL76
ATE is great but can be hard to find locally...
Castrol GT LMA is excellent and easy to find, we use it in all street cars that see duty like yours. I suggest 2 of the large bottles (maybe about 30 oz? I foget) for a complete flush
If you have a power bleeded I also have found it way easier not to add fluid to the bleeded (only air) and add the fluid only to the resevour as it becomes low (watch careful or you introduce air into the system and have to start over) but it makes it way easier to clean up - also remove as much fluid as you can from the resevour before adding new so yopu dont have as much "mixing" (I use little syringes from the pharmacy, they are free and disposible)
lastly any open unused fluif... recycle (discard) as it will absorb water on the shelf... the stuff is cheap so no need to take a chance later of adding bad fluid
Cool, thanks for the info. I did a little research on the ATE Super Blue and found that it's BANNED in Florida! The ATE Gold is legal; they just don't want blue brake fluid in the State. I'm glad to see my lawmakers are focusing on the really important stuff instead of violent crime or welfare fraud.
For some reason, a couple of states have done so. So then you order it online, and they ship it in; so much for legislative actions...................
I don't use the "blue" fluid because it stains everything including the brake reservoir. My guess it makes the fluid hard to recycle as they have to clean the dye from it.
  • 2 months later...
Hmmm . . so that's why my reservoir is bluish.
Gotta clean it up (if i still can) & fill up with Motul RBF600.
:renntech:
