Happy new year guys, please advise on the following,
The car is now at the dealer, with the following serious issues:
1. Huge Fuel Consumption (avg 50 liters / 100 KM) - 4.7 MPG
2. Extremely high emissions on the exhaust, like 10 times more than normal, plus smoke. White/bluish smoke.
They are not sure what it is, the car has been there for 2 weeks, please give me something to tell them at least... they are so incompetent, it is unbelievable.
I was supposed to renew the MOT, but with these emissions, there is NO WAY !
What could it be ?
So far, the coils and sparks turned out OK, whatever else they verified they said it checked ok... still the smoke, high emissions and 4.7 MPG.
Edited by poleposition
The CEL was on, but due to a bad wire on a coil, so now it is off, still the problem remains.
If there were the lambdas, the CEL would light up right ?
I don't understand how it can be off, with all that smoke !
That does not sound good, head gasket, headers damaged, it would help if you could list the codes
Whats the repair history on the vehicle? Was it operating correctly before the MOT inspection? Also inspect the oil for fuel contamination.
The car was serviced only at Porsche Dealer, no major repairs, before this MOT, everything was fine.. well, i've noticed a bit of smoke when the engine was cold, but that was it.
Head-gasket is ok, coolant level ok.
They mentioned a few hours ago the lambda probes, but this morning they said they were ok. Sorry, it is 9PM here :)
So they can't give me an answer for the 4.7 MPG fuel consumption... or could this be from the lambdas ?
I hope they will give me some error codes for me to post.
Thanks.
If it developed a misfire due to a faulty coil pack and it has now been replaced, clear all codes and road test the vehicle to complete at least one drive cycle. You might be trying to repair a problem that doesn't exist due to the fact that the DME is still adapting from the misfire fault.
UPDATE:
Just got a call from the garage:
They told me the emissions are now perfect, what they've done was, and i quote "a reset/self cleaning procedure on the lambda probes", and all is fine now. And of course the car passed the MOT.
Do you have any idea what that means ?
I would guess they just drove the vehicle to recalibrate the DME and purge the cat convetors, just what I would have done.
