Hi Guys. I'm planning to swap out the factory Bose system in my 04 CTT for an aftermarket system. The OEM amplifier is malfunctioning and according to the dealer must be replaced. I know I can't go aftermarket on the amp alone (due to MOST), so I'm planning on an aftermarket nav unit, amp, speakers and sub. Any words of wisdom before I start?
Not really, if your scrapping everything you might have to tell the system by deleting the components with PIWIS. Sounds like an expensive job given that you will have to rewire most everything and lose steering wheel controls. I would swap the amp personally
