Hi
looking for the part number for the cable mech on the RH front door (drivers door, in the UK)
is the mech available seperately ?
only the cable is broken - result of glass frozen to seals, and trying to operate window...
so, ideally, I just want to replace this section.
also, anyone got the procedure for the mech replacement & trim removal ?
I've got all of it off , but there appears to be two blind rivets into the door lock mech, that I don't want to drill out, as I cant see a way to get them back in !
thanks
David
Thanks Loren;
I can find reference to the leather trim removal, but not the inner door trim sheet metal - looks like there are two rivets from inside the sheet !
I've drilled out the ones on the top, but can possible replace the mech without removing the other two rivets.
