A couple of words about me.
38yo, from Italy, now living in Switzerland.
My brand new/old car :o
997.1 C2S - 2007 - 25.000km (~15.000 miles)
Specs/options
407 19 inch SportDesign wheel
425 Rear wiper :mad:
567 Windscreen with grey top tint
666 Telephone module
670 Navigation module for PCM
998 Leather interior in natural leather
P12 Automatically dimming interior and exterior mirrors with integrated rain sensor
P17 Sports suspension (- 20 mm) incl. rear axle-differential lock :D
X51 Power Kit Carrera S :D :D :D :D
XCZ Sport shifter :D
XRP Wheel spacers, 5mm
A few pics (just taken while driving back from the supermarket and my girlfriend was not overexcited of my idea of taking pics :P)
  • 11 months later...
It's rare to find one with the X51 Powerkit option installed
Better not to say to loud that when I found the car I had no clue of what "X51" was.
I've chosen this just because, compared to other I had seen with similar specs, mileage and price, it had a nicer carbon air-filter box :lol:
  • 6 months later...
I am a beginner as well, so feel free to correct me if I am wrong.
From outside, if it's a manual transmission C2S you can see it from the middle radiator in the front.
In the engine bay it's easy. The carbon airbox is easy to be identified.
From inside, by the grin of the driver.
Edited by Ale_72
You have some great videos and pictures on your site, it's always a pleasure to hear that throaty roar of a 911 zooming by. Looking forward to seeing more! Enjoy ^_^
I called yesterday to book a dyno test my car in an "official" center (not linked to any chiptuner) but they have no available slot until Sept.
Edited by Ale_72
Excuse me a beginner's question
Can you see if your vehicle is equipped with a power kit?
Look if this helps.
Could some elaborate a little on the P17 Sports Suspension that Ale_72 mentions in the list of options his car came with please? I tried a search but nothing related came up.
Thanks....
Cannot tell you much more than this (various copy/paste).
I hope this is what you were looking for.
Suspension struts (front axle)
The spring strut consists of a double-tube gas-filled shock absorber and a conical spring which in turn is adapted to the different vehicle variants.
  • PASM chassis Spring rate: 33 N/mm
  • Sports chassis (-20 mm) Spring rate: 36 N/mm
The springs have a colour coding which indicates the spring tolerance and/or the chassis version.
Suspension strut (rear axle)
The suspension strut consists of a single-tube gas-filled shock absorber and a coil spring which in turn is adapted to the different vehicle variants.
  • PASM chassis Spring rate: 56 N/mm
  • Sports chassis (-20 mm), spring rate: progressive 60/90 N/mm
A single-tube aluminium shock absorber is fitted in order to reduce weight.
The main way in which tyre comfort has been improved is through the use of new support bearings with optimised shock absorption characteristics.
In accordance to the versions, the support bearings (three variants) and the lower spring retainer are manufactured in different versions.
Stabiliser
The stabilisers’ setup in diameter and strength is designed to match the vehicle’s weight and driving dynamics.
  • PASM chassis Tube 19.6 x 2.6 mm
  • Sports chassis (-20 mm) Tube 19.6 x 2.6 mm
The relocation of the stabiliser attachment points from the suspension strut to the wheel carrier has increased the transmission ratio of the stabiliser.
The stabiliser responds more directly as a result, which more effectively reduces the tendency of the vehicle to tilt when cornering.
Sportiness and PASM
The chassis approximates the sportiness of the sports chassis when regulative interventions are made with active PASM
Mechanical rear differential lock
Only available with the sport chassis option.
Edited by Ale_72
